Solid red lights in rear... HELP PLEASE
I crashed my DJI Phantom 2 vision and after replacing the blades and putting the battery back in it will no longer fly. When the Transmitter is powered on and then i power up the Phantom i get solid red lights in the rear and no lights in the front. When go i through the start motion on the transmitter they blink and then go solid again. If i turn on the phantom without the transmitter on i get the green/yellow/red cycle. I was advised on this forum to change the Compass and i have done that. also changed the cable to the compass. DJI has told me to send it in but i am really hoping that there is something simple i am missing. I dont have the money right now to send it to DJI.
Any help or diagnostics would be greatly appreciated.
Hook to PC ASSISTANT,
Check your IMU readings:
Gyroscope
Accelerometer
Compass
Let us know your MOD VALUES?
IMU= Inertial Measurement Unit
( takes readings from ( gyroscope, accelerometer, & compass )
It takes the values and creates a MOD VALUE for each.
MOD= MODUUS
( another term for absolute value )
Basically goes like this:
Gyroscope SHOULD BE : ( 0.0 - 1.5 )
Accelerometer SHOULD BE : ( .98 - 1.02 )
Compass SHOULD BE : ( 750 - 2250 )
If any numbers above are OFF, perform a ADVANCED IMU CALIBRATION.
Also run a Tx ( controller ) calibration while you are still in PC ASSISTANT.
Do a FRESH COMPASS CALIBRATION before first flight! All should be well.
If for some reason your compass IS WAY WAY OFF ( like in the negative numbers )
You'll need to do a compass RESET .
How to reset compass below:
http://youtu.be/kCT1rRE_UIg
Take care, Fly safe!
Supercell
