Repaint props
I've heard if some folks staining them (Rit Dye), that is the preferred method, I believe. But I have painted them black myself, then re-balanced them. It was a spray paint from Krylon made for plastic. Worked fine. Plasti-dip is too thick and heavy, I would assume. Plus it's peel able. Not good, mid flight!
dye them works best
Reactions: Techcop50
Has anyone tried dyeing P4 props? I'm just wondering how we'll it'll work since there is now a glossy finish on them.
Haven't done it but I would suggest dye as well. If for some reason plasti-dip starts peeling mid-flight, it can get caught up in the motor or cause a nasty unbalance.
I found this recently - a 'how to' guide for dying plastic with Rit dye
I used a black Sharpie pen and masking tape to put three approx 3/4 inch bands on bottom of prop with alternating white bands, looks cool when running
Reactions: trevornewkirk
I like this idea
I used this method way back when I was a kid dying nitro rc nylon wheels. It looks cool and doubt it affects the reliability but the only concern I have is when you require warranty work involving a prop failure. Might not be a good idea in that scenario. If your warranty is up why not though.
looks great
