Can anyone shed some light on how to get the existing UV filter off my bird to add an ND filter. I used the tool that comes with the P3 for tightening blades which fit snug around the filter and still wouldn't remove it..thanks
I just stumbled across a pretty solid, easy, and CHEAP solution.
Phantom 3 & 4 factory lens removal tool
Dam...I'm having the same problem -- actually broke the tweezers - by mistake of course. I can't get this darn thing off.
Spray some WD40 into a small vessel. Then unse a tooth pick or something similar to put a small drop or two onto the thread area.Dam...I'm having the same problem -- actually broke the tweezers - by mistake of course. I can't get this darn thing off.
Personally, I try and avoid any kind of petroleum based products around plastics. Some plastics can become degraded when exposed while others are fine.
I started with light hand/finger pressure and unfortunately it has escalated......I'll calm down and try tomorrow
