Remote controler update
I have successfully updated quad and remote but the "Overall Status" on my sreen keeps saying "Remote Controller Update Required" ???? Help, I'm down and its the 4th !
P3X_FW_V01.09.0060
Thanks in advance....
Which firmware versions do you see listed in the "General Settings" --> "About" section of DJI GO?
Are those the versions you see when your remote controller and Phantom are turned on?
I'm not sure, I am at work and only looked at my phone. I will check as soon as I get home and report back. Thank you.
Okay. FYI, the firmware versions will only be displayed when your remote controller and Phantom are connected to DJI GO.
Remote Controller1.1.8
Since your remote controller firmware is older than 1.3.2, you should install 1.3.2 using a memory card and then the latest version of the firmware using DJI GO. If needed, you can find detailed firmware installation instructions here.
Reactions: Txmark117
