Planefinder
I've seen different versions of this (flightaware.com for example). Be aware that it only shows aircraft on IFR flight plans (a fraction of all flights and a tiny fraction of flights close to the ground) so don't expect to use it to keep your P2V out of my props. ;)
I have had it a while now, kinda mind boggling how many planes are in the sky at any one time.
That
That's what got me when I seen it first time :shock: the air traffic control staff must be stressed
I've got no intentions of going up 35000ft ;) just nice to know where the airline flight paths are
That data is 15 minutes old at the best. AFAIK, you don't have to file a plan for VFR trips. Best bet is to stay low and fly safely.
Well I tested it today and every time it said there was a flight passing over my house there was a plane in the sky going in the right direction?, I don't fly here anyways as I believe I'm too close to an airport (10 mile).
My partner thinks I'm going to turn into a plane spotter :)
In the US at least, flight plans are not required for VFR flight (I haven't filed a VFR flight plan since I was a student). Flights above 18,000 feet must be flown IFR, so you can usually bet that if it's a jet it'll be IFR.
You are not too close to an airport if you're at 10 miles !
Awesome app! Thanks!
Supercell
