Phantom V2 getting five red error lights
Hello, I searched quite a bit and have been unable to find this same error.
I disassembled the body and MB for painting. Upon reassembly I always get five red error lights when engine start is attempted and no engine start. I can make this happen right after power on and or after half the compass cal. (vertical fails) and lights are blinking slow yellow otherwise. I have recalibrated the compass but need to know if the five red error lights are false battery alarms or still a cal issue and I need to get a complete compass cal befor engines can start? The assistant shows good numbers with the battery.
Thanks for any help
i assume you messed something up taking it apart. go back through you work and check everything!!!!! you obviously had something go wrong during assembly. maybe a loose or pinched wire? good luck :shock:
I had this same problem and haven't figured out the solution. Were you able to get your's back up and flying?
