Phantom 3 gimbal error
Hi all, I'm opening this thread as a few weeks ago my phantom 3 standard fell from about 5mt high damaging the Y motor, lower board and landing skids. Black ribbon cable and main gimbal power terminal block (white connector) in very good condition.
I purchased and replaced the above damaged components. Once the radio control and the phantom 3 standard have been switched on, the leg does not initiate any movement from the motors even with the roll present in the radio control.
Flashing green led on the gimbal main board, trying to move the motors manually a slight rustling is emitted.
The connection to the dji go app is successful, no error on the app, video stream from the camera is transmitted successfully on the app, but it is not possible to record or access the camera settings menu.
Trying to turn off the drone, it stays on for about 20/30seconds and you can also see only the red LED flashing in the battery power button.
Possibles solutions??
PS i have a good experience and instrumentation in electronics.
i think you shold be reply your gimbal with the new one, maybe
Welcome to the forum!
Why can't I see all of your posts, etc?
How long have you had a P3S?
Well Anyways, I will post a link to a very good diagram that I'm sure is accurate.
There is a reason why, "P3S => Fly-it or Fryware-it (Rod)" is in my signature,
Rod ..
Pruzhk4
