Phantom 4 - How to connect iPhone 15?
I was gifted a DJI Phantom 4 by a drone pilot- and it is my first drone.
I want to take it out to practice in a large, drone-friendly field, however, it does not seem to allow me to use a USB C cable to connect it to my phone, or allow me ot use a lightning > usb C adapter for my phone.
Sorry if I have confused myself and made this more complicated than necessary. I would like to know if there is a way I can connect it to my iphone via cable.
Thank you in advance!
Reactions: RodPad
Welcome to the Forum.
You should be able to connect a good USB < USB-C cable from your phone to the remote controller. Use a good quality data transfer cable.....not a cheap charging cable.
Also, check out 'Phantomhelp.com' by msinger, an approved vendor here on PhantomPilots. There you will find boatloads of information. Just be sure to select the correct drone model from the drop down menu. The official DJI Phantom 4 owners manual is also available for more information.
Reactions: RodPad
Thank you! Do you know if there's any good data ones at officeworks or similar? Everywhere online says its not compatible with data transfer despite having it listed as data cable.
Reactions: RodPad
Not sure, your profile doesn't list your area. Beware of online sellers. Most are just charging cables.
Reactions: RodPad
DJI Go4is the app, the fly app is for the mini series etc, as for your iphone its hit and miss if they work, i have an ipad with USB C and i cant get it to see my p3a quad, yet my android phones all work fine.
as for an adapter, these have always been a fail point, it has to be the correct USB A to ...... whatever your phone has as a socket
Reactions: RodPad
Here is the Phantom help site.
You find links to a lot of things Owners Manuals, Etc.
Including this one.
Rod ..
Reactions: captainmilehigh
You'll need a USB-C to USB cable that supports data transfer (like this cable).
Also, make sure you're only trying to use DJI GO 4. DJI Fly is not compatible with the Phantom 4.
Reactions: jdt1944 and RodPad
The problem he may be having is the fact that the Iphone 15 may not support the Go4 app. Many newer phone Android or Apple do not support the older app any longer. It may be best to use an older tablet or phone (I7-10 or Android version lollipop) or get a 5"/7" crystal sky monitor
OP listed this in the Phantom 4 slot. Last time I checked, OP should be using the
DJI GO4 app. I’ve been rong several times this month!
I missed the 4, post now edited thanks
mithRSM
