P3 Firmware phantom 3 standard does not sync
Hello and excuse my English, but I am from Spain.
I have a problem with my phantom 3 standard. I am not able to synchronize the controller with the drone. I have tried every possible way and I can't.
Then when I saw the txt file I have seen that the updates failed or are updating, but it does not finish doing it.
I attached the information of the txt.
Thank you very much and I hope to have help !!!
========== 2016.06.02 18:47:20 =====================
Packet: P3C_FW_V99.99.9999.bin
Upgrading ...
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2016.06.02 18:51:55 =====================
========== 2016.06.02 18:56:27 =====================
Upgrading ...
Result: Success.
========== 2017.11.22 22:01:23 =====================
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3C_FW_V01.09.0200.bin
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Packet: P3C_FW_V01.07.0090.bin
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3C_FW_V01.05.0070.bin
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Upgrading ...
Upgrading ...
Packet: P3C_FW_V01.06.0080.bin
Upgrading ...
Result: Failed.
Upgrading ...
Try to format your SD card first. The FW should be the only file on the card. When I have probs with cards (not recognized in a device or making funny things) I use SD Card Formatter.
OK, thanks a lot. I have tried but it doesn't work. I read in a forum that adding a file without an extension called P3C_FW_DEBUG worked, it doesn't work for me, but at least there is no failed update
Pruzhk4
