So, Amex and VISA won't play... Lets see what MasterCard does in this case.Amex wont cover it, been there done that.View attachment 20834
Just sent off the forms and Data, in any case hopefully it will help everyone if there is any useful data for future updates if there is an issue.
Hopefully if it isn't user error then a mutually beneficial option is reached![]()
Good to know... I had 4 successful flights taking-off from a marina (concrete) dock loaded with yachts this past weekend. Hovered to check things, then went up to 150' to get past any interference from the sailboat masts before venturing out. Guess there is no re-bar in the dock, but I was worried about interference from the yachts.be careful, most concrete has tons of rebar. This is one of the hardest thing to do while flying at places like CES or NAB. Finding a good spot between the metal in the concrete so we can safely take off.
Why not auto takeoff?I wouldn't take off in ATTI mode ( I suspect you do that to avoid GPS tipping you over at 0 alt).
GPS mode
CSC to start motors
idle a bit to ensure no issues
stab the throttle to "jump" you off the ground and up to 3 or 4 feet...
hover for a bit
go have fun
...but that's just how a n00b like me would do it.
GPS mode
CSC to start motors
hover for a bit
go have fun
I see no reason to take off in atti.There's just no reason for it really....
...I'll even follow that with an "in my opinion".
Not saying it's wrong to do so....just not necessary I suppose...
EDIT: I'll even add, if you are going to fly around in altitude mode, then sure, take off in it as well.
But if it's a gps mode flight? why take off in atti?
However in my opinion whenever you do a CSC you risk doing something stupid with the sticks, and that's why I just click and swipe now.
Edit: no reason to take off in atti if you can use GPS
All good, confused me for a bit. Was just thinking you should say CSC or auto. To each their own.haahaa! I read that as why no atti take off....LOL
* changes prescription*
I'm sorry, let me try that again...
Hmm why no auto.
I dunno' just used to flying RC with sticks and not buttons? I guess...
I see your point about a slip of the thumb, but because I idle for a bit, I prolly' let go after CSC.
Here's my CSV from the first flight (thanks for uploading your .TXT!). There is a ton of crazy stuff going on in here, including:
This looks way worse than just concrete rebars or bad compass calibrations - this looks like a faulty IMU or even flight controller. I'm amazed the quad survived the first flight, it must have been completely uncontrollable. I don't think a faulty compass on its own could cause all of this, the accel or gyros must have been way off.
- Altitude values are all over the place. At one point the Phantom thinks it's 600 meters underground.
- Pitch and roll are insane. About 1/4 of the way into the flight the roll in degrees goes all the way up to 180 degrees, then wraps around to -180 degrees. For much of the flight it's stuck at -115.8 degrees.
- The yaw is way off. The quad rotates hundreds of degrees without any rudder input.
- The controller is constantly complaining about SPEED_ERROR_LARGE and COMPASS_ERROR_LARGE.
It all looks very similar to the classic NAZA and Phantom fly-aways of yore. I guess DJI hasn't fixed whatever bug or hardware issue causes those, after all.
25 flights with the P3, 4hours 25 min 104,000 MTyler, how many successful flights did you have before the first bad one?
You have a wonderful attitude, I'm I'm sure they will take care of you.
Could you please share the name of the app, sounds like something that could come in useful.I use an app on my phone that gives me the total field for the phone's magnetometer using a sum of squares algorithm.
I raise and lower the phone being careful to hold it in exactly the same orientation the whole time. If the value changes too much, I know there's a local field and move elsewhere.
