Phantom 3 drone down
You don’t need to throw the card away.
Try downloading a video file repair program, there are free ones available. You can also use VLC Media Player (also free). I’m told it will attempt to repair a corrupt AVI index so good chance it will let go see those final moments Rod is desperately waiting to see.
Pleased to learn you found your AC.
There's actually no simple way that I know of to automate altitude AGL estimation along a defined track, but I can describe the method I use in case it is of interest to anyone or, even better, if anyone can suggest a more efficient method.
Litchi exports a kml file that defines track points at the mission waypoints (plus 4 extra track points per waypoint to define each curved turn). For the current example that looks like this:
We can extract the lat/long pairs from the sparse output, import them into Igor Pro, and run a custom function to create cumulative distance for each waypoint. The kml file also gives altitude AGL at each track point, based on Litchi's DEM and the mission waypoint altitudes above the take off point, so now we have lat/long/distance/altitude AGL values, but it has no information about altitude AGL between the track points, and so the values are only correct at those track points:
GE can display a continuous, interpolated, altitude MSL profile for this track, and you can also clamp it to ground to get a continuous ground elevation profile MSL under the track, but it will not display the difference and you cannot export the data, so that's a dead end in terms of trying to generate the flight altitude AGL resolved across the entire track.
However, we can use the GPSVisualizer website tool to apply a DEM that discards the altitude data, creating a second file that has ground elevations MSL rather than flight altitude.
Now we have two data files, one describing the flight path altitude AGL and another describing the ground track altitude MSL under the flight path, but only at the sparse waypoints that define the mission. If we add these datasets then we can reconstruct the mission altitudes MSL at the mission exported track points:
Note that it looks approximately as expected, since all but one mission waypoint had identical altitudes above the takeoff point. The variation, which is of the order of a couple of meters, is due to differences in the DEM used by Litchi vs. the DEM used in this calculation.
The linear interpolation of the flight altitude MSL is usable, since that is how Litchi flies the mission. That's not so for the ground track elevation data however, since the ground does not behave like that in general between mission waypoints. It would be great if GPSVisualizer could take such a track defined by sparse track points and create an elevation profile at an arbitrary spatial resolution, but it will not do that - it only returns elevation data at the input track points.
To get around that problem, we can take the lat/long/distance/flight altitude MSL data and run a linear interpolation scheme to produce new values at equal distance intervals. In this case I created 1000 interpolated triplets giving a uniform spatial resolution of approximately 5 meters:
Processing those track points again using GPSVisualizer's DEM also generates a much higher resolution ground elevation profile:
Now we can subtract the high-resolution ground elevation profile from the flight altitude MSL profile to get a high-resolution flight altitude AGL profile:
Comparing this to the second graph that shows only flight altitude AGL at the exported track points illustrates the reason for generating the higher resolution ground profile.
We need to put this in the sticky thread. This is so useful. Thank you sar104 for that mate [emoji4]
Reactions: kmckinnon
Agreed, VLC has repaired a few files for me when I first started flying and would forget to stop recording before turning off the remote. There are a few programs out there as well that say they will write an end of file for you but I have only had that work 2 times with any of those. And some files are just beyond repair also. Then there's those DAT files that you need to find on the card. The one for this flight may still be good and should have valuable info on it...
The .dat files are written to an SD card inside the AC, not in the removable card that stores photos and footage.
Reactions: robby4570
Ok, i will give one a try
Sorry.....i did retrieve files on my pc. Windows media
Are you saying throw the card away?
No, Don't use the card to do the repair, what is on the card is you only original copy.
Copy from the card, do the repair on your PC.
@LUIS J, fine tuned, or made the DJIFIX program little easier to use.
You use a video that you know is the same settings as the one that is damaged.
Pick the file that is damaged, pick a file that has the same settings, and run it
When you run this program it does not modify the damaged one, or the good one, it creates a new file from it, so your original will be untouched.
This is the beginning of his thread.
App to fix corrupted Video Files (new one)
Page# 8 Post# 147 ;) Is a link to his program.
When I downloaded in the past, I created and copied to folder in the root of Drive C: "Fixit"
Copy your good file and your corrupt file to same folder, makes it little easier then chasing were the files are when you run the program.
This may get you around Administration Rights issues.
The program will be zipped.
Page# 8 Post# 104 ;)
The original creator of DJIFIX chimed in. Stating his is free, Luis asks for a small donation.
Your Turn. :D
Rod
VLC is the most Popular, but I quit using it, I have liked Pot Player better.
I install all the added codec's when they ask.
https://lifehacker.com/five-best-desktop-video-players-1503859883
Rod
I tried the vlc and it ran for quite awhile. I tried to view after it stopped. Nothing
This must mean you haven't tried a repair?
Pot Player is not going to finish playing it ether.
Rod
Rod
I have tried a few programs that are supposed to fix corrupt sd. Trying to work with the dji exe program now.
Once i get my parts in to repair my camera connection, will it finalize the video? Or is it still bad because power was lost.
I doubt it, that would have been the first power up after the battery was ejected.
I guess you haven't tried my link.
If you load up the bad file and a good one to a dropbox etc, I will run the app for you myself.
Rod
Reactions: Snarg
Rod
Yes Rod, I did try your link. No go for me
Well it appears only one file is coming in DJI_0008.mp4 , Is this the good one or bad one, as I stated above we need a good one recorded at the same setting to repair the corrupt one. If your cheap like me and ran out of space, I let you know when I get this one and you can delete and upload the other.
Rod
Rod
Dji00008 is the bad one. I thought i had sent a good video also. Still sorta new at this file sharing stuff. I ll try again when i get home.
Usachman
