Well, I only update any code, for anything, if it has a new feature I need or a fix I need. PV assist 3 has neither as far as I can tell so far!
It appears to be exactly the same camera as before, just re-packaged into a different body. Looks like they split the previous FC200 "egg" camera into two parts - the lens & sensor board are now in the small silver case, and the wifi board/antenna is now moved out of the camera, and attached under the aircraft body. The new design makes sense - less mass for the gimbal to move around. And probably helps improve the Wi-Fi range & reception, too.happydogs said:Question: does the camera on the PV+ have same features as the GoPro Hero 3+ black? Or, is it basically the same as the fc200 on the "old" vision?
jimre said:It appears to be exactly the same camera as before, just re-packaged into a different body. Looks like they split the previous FC200 "egg" camera into two parts - the lens & sensor board are now in the small silver case, and the wifi board/antenna is now moved out of the camera, and attached under the aircraft body. The new design makes sense - less mass for the gimbal to move around. And probably helps improve the Wi-Fi range & reception, too.happydogs said:Question: does the camera on the PV+ have same features as the GoPro Hero 3+ black? Or, is it basically the same as the fc200 on the "old" vision?
gpauk said:Well, I only update any code, for anything, if it has a new feature I need or a fix I need. PV assist 3 has neither as far as I can tell so far!
Let's hope the new design makes it possible to (manually) focus the lens by turning it.jimre said:The new design makes sense...
I hate that amazon has a fake list price but sales it at msrp and say you are saving money. I got my P2V a while ago below msrp. How? I google and found a discount code for the internet dealer. It did not work, so I email then and asked for a code that work. They email back a code that worked.tizzl10 said:
Hope you are enjoying yourself... You just don't know what you're missing... Here is the 10 day policy from DJIPull_Up said:Hence the second sangria (now third!). Just finding all the different reasons people have given for buying direct from DJI interesting... Have people checked out the returns policy on direct purchase from the DJI website and compared it to Amazon, for example? You don't have 30 days to change your mind fit one thing...
Mori55 said:Wonder if the lens filter will work on the new camera ?
Who is the seller? Several members have responded that the new gimbal upgrade is not available for P2V.msecchi said:Need your feedback and suggestions. I ordered a new Vision 2 on Friday, was posted today....obviously tomorrow when I will get it I can easily return it without even open the box.
The seller says is exactly the same as Vision 2 only has the gimbal he told me...you can practice on this one and then in one month update for the same amount of money to the new Camera Mount and Gimbal....
What should I do??
AllanVB said:Who is the seller? Several members have responded that the new gimbal upgrade is not available for P2V.msecchi said:Need your feedback and suggestions. I ordered a new Vision 2 on Friday, was posted today....obviously tomorrow when I will get it I can easily return it without even open the box.
What should I do??
