P4 Temporary Threads
Glen Burnie, MD - USA
Got home after dark & I didn't want to maiden her in the dark. Not a fan of the plain white upper chassis so I threw together some temporary threads for "Nemesis" until I find something more suitable. Not the right name or intended colors but just what I had on hand at the moment...
xw7t08Z4r6FnECw3Bk9AnSVxIWO-dQvy8pgyoJJHOyv4uRl5SzmbdutMr-mlqQsrAkFmM3UfzGXM7XtbvRNw0GoxR5-CrErhwgNZgHt3U21efhYaKpTBmC0bu3aYVSiyfqf2cYIe5T5VNI0zA-qXIenC0Ms_GZAt8QdEuqcYFiB9NzepHsRfiIiNDvyb0xmHaEdeZPh_IGClRS1sp5ZNSFHQO_c0JFI2tfLzfOAUTi0dRW8DVh0KxRckSrN_gyXjOOauKA-h83-fFB1h6XXdxy8yvLNnXc7fH6JwbbYi2U7gSLz3BEkB-IaSiQc3f8srBpsf9kF_YGkGktsz9ZLmBuM9TsYWPrBBkowNTK0kLeAxu_-2N0BUa_AW3unYQQgFhZdfThSoOeupComJAEqwcIpl6mHjrIAFj_WqrBlEVjZRcTldS97i1iy_eKwI5J-BOFyt0nm1QQ77bgpBnH1vvtz-ip1To4vj3xbQCjOWW_NmbhkVLrs2QFv4stQOiUfelpbYpkH8iDipOpT92OCBtRhLe66wavUzV-DCtpAjgGg0KNS5x0H4tlECnnCU6hb-08DZXQ=w1120-h630-no
cB9cQaHnjRqFtVVEhVD2XJdL9OH83SQ7UAsrnB6lyixQLSguCpz8HYBJ7AGFwyLbRLVhzPIc2DG_HfMWvUE4Gp85e-Q7qT7x_ptptm8cHbdmEHORkGgSfNLj8qXUBwlxTFdM81LnNJ6WUJVl_oZCzNWeWE7c2Akq8OI3MMrtSvAcq0DMOp9M55RRbOkqhOd-U4BtJDdq1AaLmZwSA6z20k6MHf9odu48SC2g87emtEZSS5fUrwN_hgJGdfxXk-tt70JbEScx8jV767OTWNqzM9Ni29ed1YmESafnupltLZNOTmHQRskuFVEj7w_vePl5ydprYW-cTm1GSTcOSDqh1_RUGP1vZ3iM7pjDY4KygOtYTBjAxZ74T0UkNh1CVZQdCQnN9Wabddk0anCl9bhNhxnyNQz6twIkoPwYTZ23or2iDBVvufZ64WYEnFlDuzS_WtJUGEKYZQ1Ne5R1AYlPuBF-URoANUnFfnEaUQu487oBTmBfOJ_GbOjsx02OIKIMKJCJYBGjyksmc9_-hbwNyYuB7f-T_grB4ONCg9CChxgmdXrNpvfoQZcgTlyg5u6Ms4Slpw=w1120-h630-no
f9sr4090lpVoS4OcYYQtzZMz6m3xKPpzFsUCk9DzJ7xml1micyTqPnHWfIoANZfD7AgtN0TwmM6ma8_xYE-oovzsJIIFC975S9rmX8ci61Sk2hru7hHQleqo09IJbuYFZ8VS4dmH8TYmnF8QbjGI0pM1f4apRXqCk_2uTb6XGxvC2Gy-DBceeCbic6-wyG13ePy1Pk0GWItTcMew_0eao6MOiLjaCQaDj8tKX1xKZlyj5SoKecAEh2pKr1c3GTahy4jd9CBqkEQRspQR4Y0Pb95SUcS45r3_JfIHOfjNDf9bA14eD_i41qG2HieBBBW73vFS5CXRfVCbZB5cktiP80gwkHD6C2e4PBOEijSTxsBt128Nj7LYlh7GHz5AkYWdinCnbCBy-86Y7Om76fH91eBDSS4Dyl-se0yTqyhgKtn4j7v2PsM0YILOU_sNV55qxfLeT2H9Ij-filfxnzze8h62f7ksKVI08HwWxmmQhwbeb99nVtJF-1FukIq1W1JMuCZzB8ksFBUTb2jAlFaLpwshiwwGHUX53Iy6mo_RzpWsQABeD-fjZHPWpdmBanMKX7OvVQ=w1120-h630-no
thanks, I'll check them out. just re-shelled my p3 for the second time and looking for a little something to kick it up a notch. looking forward to seeing those P4 videos!
The "Dirty Bird" letters on my P4 are .8" high x 2.5" wide. The FAA number decal font is .25" H x 2.00" W. The finished product is .96" H x 2.66" W to account for the white background. These are 3M Premium vinyl on solid white background so they are basically a self-stick decal. The white is glossy so it blends in pretty well on a P4. Not quite as much on a P3 because the shell is matte but you only notice up close.
At this size the name decals are $1.03 each & the FAA decals are .33 each. If you want them to truly look professional you can get the letters only with no background. They come aligned on a sheet weeded & ready to install. Just peel the backing, align & press, then peel off the alignment sheet. You will want to order them ready-to-install. The name decals run $4.77 each this way. Not sure about the FAA # but I would just order the decal-style for those. They are easily removable and, until you fully press them down, repositionable. Lots of colors & font options to choose from. Note that silver & gold look like real silver & gold. Don't go for the reflective tape background as the white appears silvery & stands out plain as day on the shell. You may want to order a few extras in case you make a mistake applying them or to adorn your RC, case, etc..
What were your sizes? I like!
Reactions: suck it up
rockymountaincaptures
