  1. lawman0210
    I just pulled my P4 out after 2 weeks of no flying. Of course it needed to go through firmware upgrades (using term lightly). I got several "critcal battery landing" warnings while sitting p4 was on ground. Highest obtained speed was 22 mph. That took quite a bit of distance to get to achieve that speed. Anyone else having issues?
    #1 lawman0210, Jun 11, 2016
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I'm not sure what you're trying to say here. Can you go into more detail?
  3. lawman0210
    Original post edited
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Please upload your TXT flight log here and post a link back here.
  5. lawman0210
    I will later as soon as I figure out how to to that
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Click my link above :)
  7. lawman0210
    So I see specs say max speed 20mps. So that's roughly 45 mph. That would be sport mode. It doesn't give max speed in regular mode but I'm getting 22mph and as low as 15 mph. The p3 is approx 35mph. Can anyone give me there average speed in non sport mode? Sport mode seems normal to me but regular mode definitely seems off. This is right after an update. Did dji slow it down to make the sport mode seem faster?
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    How about with object avoidance turned off? It should be very close to the P3 then.
  9. ftttu
    Other than the bird's firmware updates, did you also update each one of your batteries?
  10. lawman0210
    Yes I believe that's when I got the "critical low battery" warnings. I will try and turn off the avoidance and see if the speed picks up
  11. stefan350
    Make sure you top off the battery as well if it's been in storage for for awhile. Today I used my extra battery and was getting battery warning at 65%. Turning off obstacle avoidance should help with increasing the speed.
  12. jwt873
    Woodlands, MB Canada
    I have no problems with my battery, but after the last firmware upgrade, my top speeds have dropped. In Sport mode, I used to be able to hit 50+ Mph easily with a slight tail wind. (My fastest to date is 57.2 Mph). Now I struggle to get to 45 Mph.
    ianzone likes this.
  13. lawman0210
    Exactly. I think dji slowed everything down. My guess is that to many people are still hitting things with obstacle avoidance on so they slow it down so the system works better.
    I turned obstacle avoidance off and it is working as it used to. 35mph and sport about 45. I can leave side avoidance options that are below the front avoidance button and that has no effect
    It's a shame that in order to have obstacle avoidance on you have to be the slow moving Ballon just buzzing around
  14. ianzone
    New zealand
    Just readin this cause now i lost lot of speed after update,,,like 30mph off top speed,,,what has happened
  15. ianzone
    New zealand
    Any advice speed loss dont plan to hit nothing so is it safe to turn vps off,will this get my speed back,,,p3s does 52mph,,,p4 now doin same speed,,,wheres the nitro button,ha
Similar Threads - sudden speed loss Forum Date
Professional Sudden battery error, and others Phantom 3 Help Aug 5, 2017
P4P+ Suddenly can't fly over 30M Phantom 4 Pro Discussion Jul 30, 2017
Professional Suddenly Having Connectivity Issues Phantom 3 Help Jun 28, 2017
Gimbal Sudden Tilt Glitch Phantom 4 Pro Discussion May 21, 2017
Litchi sudden warning? Control (Go, Litchi, etc..) May 12, 2017
