You need to be a bit more specific, but I am going to guess that you are starting the motors without props....correct? It is normal for the motors to shut down shortly after without the props, if that is what you are asking.My p3s in beginners mode I swipe take off props Stuart for a second then shuts down
Yes props off never had problem before will try tomorrow thank youYou need to be a bit more specific, but I am going to guess that you are starting the motors without props....correct? It is normal for the motors to shut down shortly after without the props, if that is what you are asking.
They will stay on for a bit at idle, but if you attempt to rev them they will shut down....at least that has been my experience although I grant you that is a rarity.Yes props off never had problem before will try tomorrow thank you
Welcome!You need to be a bit more specific, but I am going to guess that you are starting the motors without props....correct? It is normal for the motors to shut down shortly after without the props, if that is what you are asking.
CAN I say a massive thanks for the help it was as you all said I was being a right plonker lol so thank youMy p3s in beginners mode I swipe take off props Stuart for a second then shuts down if I start in manual it's fine can anyone please give me any advice as I'm new I want to use beginner mode to start thank you
