One motor not spinning.
One motor not spinning at full speed.. keeps twitching back and forward. is there a way to re calibrate it. something with the ec or recalibrate to the remote. Any ideas.. thank you
Have not had that happen. To be honest it doesn't sound good. Perhaps a bad motor? Might want to open the shell up to check motor wiring to see if one has come loose.
You can buy 'em for $19. It'll be a v2 and it'll work with whatever motor you have. Open up the top. Remove two screws. Don't lose your lamp cover underneath. Disconnect the cable. Heat up the solder points to disconnect the wires. Remove the bad ESC. Solder the obvious connections for the new ESC. Replace screws and lamp covers underneath. Reconnect the cable. I bet there's a youtube vid on how to do it. It's not as difficult as you might think...
I changed the motor and it was fine.
Until 2 yrs later when the wifi module went bad which I'm still trying to figure out.
intertronixlabel
