Need help iosd won't update
So I got to setting up and trying the ground-station without the IOSD mini connected and no fpv this time about.
Anyway I have been trying to update the iosd mini through the PC software but it glows a solid red. Anyone have the same problem and shed some light on this issue. I double checked all the wiring. No luck
Just a thought. Make sure you are using the DJI iOSD Assistant software and not the DJI Phantom Assistant and you are plugged directly into the iOSD. That is the only thing that comes to mind.
Yes I'm using the iosd assistant software 4.0 still really heats up,and won't detect on my PC. Someone please help me setup my last piece of intelligence . Solid red and gets really hot after about 3-4 minutes.
Checked all wires connected USB to iosd video in out connected correctly and canbus also connected. :( been trying I stalking the driver again. Btw mine shows iosd not iosd mini is iosd software. :?:
Sounds like a driver issue to me. First thing is to confirm the DJI Driver is installed properly. If you plug your P2 into the normal Assistant software can you see everything ok, calibrate etc? Once you've confirmed this, turn the phantom off, disconnect the USB. If this fails, download the correct driver (DJI WIN Driver Installer) from here
http://www.dji.com/product/phantom-2/download
Now, make sure you've got the correct software for the IOSD. Download the 'iOSD Assistant Software v4.0' from here
http://www.dji.com/product/iosd-mark-ii/download
Install it but DON'T run it yet! Now plug into the IOSD Mini & power the P2 back up. Now run the IOSD Assistant Software once the P2 is powered up.
I found sometimes that the P2 & the IOSD aren't recognised if the sofware is already running before connecting. The sure fire way to make sure you get a connection to to close it all down and only run it once the P2 is connected and powerd up.
Give it a go and let us know how you get on. The red light isn't good, it means there is a problem communicating. If the driver reinstall / update doesn't work, try a different USB cable with a micro USB connector. If both of those fail I would say your IOSD is DOA :-(
Right so I did all of the above. Is it possible I may have connected the video in and out reverse ? May have caused a short ? No idea? I do get a red light and it gets really hot. This has been an issue before all the updates. Should I get in touch with DJI?
The problem I was having was due to unsigned USB drivers. Here's the fix.
DJI NAZA-M & Windows 10
Better, and easier, option is to install the new assistant 2 sw from DJI. You can't use it for the older stuff but it installs a new driver that work on win10. Now all my older Naza m, lite, Rc, phantom, iosd assistants use this driver. Works great[emoji6]
Sendt fra min Sony XP via Tapatalk
Usachman
