no I always activate RTH via the UI. I may try this. Every time my video freezes from loss of signal and the full color goes to black and white. If I try RTH it fails every single time. Doesnt make sense to me I thought it was a fail safe for low battery or loss of signal. I assume RTH shouldn't need a signal to work?have you tried activating RTH via the S2 switch?
Sorry to hear you're having a problem with RTH. If you've verified that all your RTH settings are active and correct, I suspect something else may be going on. If there's one thing I can count on with my P3S is the RTH doing what it's designed to do. In spite of all the times that I've lost control signal, or disconnected and never reconnected, RTH has performed flawlessly. Even those times where I completely lost control signal and didn't hear RTH engage, a few minutes later I hear the familiar swarming of bees in the distance.
I live in the suburbs, so my distance there is not the best. Maybe 3000 - 4000' due to a lot of interference and obstacles, so I really don't fly there any more. Where I fly out over rural farmland, I get some great distance. Today was the first time flying in two months because of bad weather. Got a few good flights in with my P3S and P4. The P3S got 5300, 5400 and 6300 before RTH kicked in. I've gotten a bit more than that before, but that was good enough for today, and I didn't really push it any further. Try driving out to a rural area and fly there. You should see an noticeable improvement. Good luck. Hope you get your RTH issue resolved.
I suspect this may be due to the ancient Galaxy S4 Im using.
I dont think im a distance junkie but its a bit disheartening when I continuously hear about just about every other PS3 owner reaching far longer ranges than I ever have.
For what it's worth, your not alone in getting less than the published range. While there are some pilots that report better than advertised distance, there is a larger number of pilots who report the type of range that you're getting. After reading hundreds of postings, I have to say the number of pilots getting anything significantly better than advertised range is small. My suggestion is to try and fly in a more rural area to see if your range issue is due to hardware or interference/obstacles. Good luck.
Not sure if its the size and weight or other factors. But it may just come down to the risk / reward math. I asked them why they preferred the P3Standard over other more advanced drones but never got a definite answer. I will continue to experiment with differing antenna configurations and improving the tripod I made on the fly to see if things get better.
I would tend to agree with that assessment. The P3S is very capable of shooting fireworks displays but would be more expendable than, say, the P4 series were something to go wrong, not that anyone would want to sacrifice a P3S. While not as advanced as the other Phantoms, for the investment, a P3S is a very capable and proven performer.
I would definitely get to the bottom of any rth issues you're experiencing.
Oh yes. Good luck same here where I live and its over a lake. But I attended last year with no drone. We were so close to the launch site, fireworks debris were landing on our heads and the area was engulfed with smoke. We knew we were very close from the intensity of the sound. I can easily launch from there un noticed. Hopefully I dont suffer a direct hit.A fireworks display will happen soon around July 4th. I will likely have to do this on the sly. But if my drone survives I will share footage.
