I'm not seeing it at Help - Litchi Is there another help section? Wait maybe it's "When initiated the aircraft will first rise to 6m altitude if it is below that threshold, then proceed to the first waypoint in a direct path. Make sure there are no obstacles between the aircraft's initial location and the first waypoint. "I posted this scenario on litchi's group and they have added this to help section
Sent from my Nexus 5 using Tapatalk
Wish they would add the just make the first waypoint at your take off spot.
I'm really into 100% autonomy. I absolutely want the thing to automatically take off do a set mission and land on its own.For all practical purposes it is. Wherever you hit Play is where it takes of from. Do you know how to regain control and stop Litchi?
I would assume your first way-point was in site? If you see it heading that direction you should flip it back to pilot control.
I normally manually raise my elevation to about the height of my first waypoint before I hit play.
Bad idea, as you found out.I'm really into 100% autonomy. I absolutely want the thing to automatically take off do a set mission and land on its own.
Just make sure tie first point is altitude change and you should be good.I'm really into 100% autonomy. I absolutely want the thing to automatically take off do a set mission and land on its own.
As long as I set first Waypoint to take off spot with a high attitude I should be fine.Bad idea, as you found out.
Even if I set the attitude for each waypoint at 390ft? I got the impression setting WP1 at takeoff point and attitude at 390ft would have it fly diagonally say 5ft horizionatally to 390ft vertically.100% autonomy is fine. Just need to set your way-points correctly. If you made your home point way-point #1 you would have had the same exact issue you had when it headed for way-point 2. TREE !
Operator error and live and learn. Now you know. Just set way-point 1 above your home-point to a safe elevation and go.
When I take off I am always ready to flip back to pilot control as I could have messed up my mission setup. Always be prepared to abort your mission
I'm off topic, but we're here to get informed and to inform.Btw. The hot coffee lawsuit that became a mokery of the US legal system around the world was with a well know hamburger franchise not Starbucks. Good for sdharris he lives in England so Starbucks is less likely to sue him for defamation Just lovin' it ☺
If your way-point was 5 feet from your home-point then you would be correct. But 5 feet horizontal and 390 feet up is basically straight up.
I personally do not hit the play button until I have launched manually and am at safe height.
All comes down to knowing it flies a line between wherever you hit play an WP1.
Wish they would add the just make the first waypoint at your take off spot.[/Q
I always create my first waypoint a the bird with a good altitude. then create my route when using Litchi.
I'm in a happy mood now. Able to spy on the intersection from bed with the standard. I wish DJI would just hurry up and make this thing fool proof. Seriously autotakeoff and do waypoints = awesome
Thank god I bought a backup drone. Too bad my backup is a standard. Oh well. Litchi decided to go to waypoint at 25 ft into a tree crashing into my car ripping gimbal completely off breaking props even though I had guards. The attitude I set was 390ft. I was doing autotake out then auto go to waypoint.
