Limited distance
Hi guys. I had a huge problem the other day flying my P4P. I icked her up and manual followed my car while my wife was driving through and a forest. The footage was epic !!!! But unfortunately I reached the maximum flight distance from point of lift off and it stopped in mid air.[emoji15] [emoji15] Unfortunately I was in an area where I could not load safely and was not able to drive back to an area where I could. Needless to say hovering around trying to get her down was difficult and almost lost it.
So my question is how do you remove the maximum flight distance allowed. Can a person even do this?????
Assuming you don't have the go app limited distance and height issue (logged into your account), in your main controller settings, be sure not to have your maximum flight distance slider enabled. If so, switch it off and you should only be limited by your control signal.
I'm going for a flight in 4 hours and will give it a try. Thanks for your advice !!!!!!!!!
If the "Enable Max Distance" setting (see the screenshot below) is not enabled in DJI GO, then check out this post.
fiweli
