Life without camera attached
Does the camera plays more role then recording and firmware upgrades? While waiting for flex cable gimbal. I have just fixed the gimbal board to the aircraft and both antenna cable connected to the gimbal board. Camera and ESC boards is not attached due to cable haven't arrive. I notice below when I turn on.
Air crafts turns on and flies fine but I have following issue
1) can't set max distance , Max altitude.RTH altitude. Shows digit Zero in red. It will give error can't set config or something.
2) GPS - sattelites connected display intermittently. At times show 7-9, then shows zero and grey out
3) shows RC battery level, but nothing on AC battery.
4) it does show in the map exact location of the RC.
Is there any dependency here on the camera+esc to be attached for all above to work? I was hoping I can still fly as normal and use return home function without camera.
