How can I do the IMU calibration???Make sure you do an advance IMU calibration afterwords... I needed to do that. No update to the RC in 1.1.9
If you check the release notes for 1.1.9, you will notice it states the controller does not require the 1.1.9 firmware.My 1.1.9 upgrade succeeded on aircraft, but failed on controller. There're log file that describe so. The *_AB.txt file says failed because it's older or the same version.
Is it possible that my set shipped with 1.1.8 aircraft and 1.1.9 controller? (shipped around May 20th)
Also, upgrade fail (ignore) then the controller returns to normal operation in a moment - I couldn't recognize the lamp changed to solid blue even in a moment, wait few minutes... confusing.
OK, thanks... I missed it.If you check the release notes for 1.1.9, you will notice it states the controller does not require the 1.1.9 firmware.
I am in the process of updating my P3 firmware 1.1.9 Does anyone know if it is necessary to do a firmware update on the controller as well?
