Phantom 3pro 1.11.20 update
I am searching for the latest firmware update 1.11.20 for 3pro and controller. Can anyone help with this issue. Thanks in advance!
Reactions: RodPad
Welcome to the forum. Have you tried DJI’s support page?
Also, why is it that you want to make a FW change? Please let us know before you do anything you’ll regret.
  • Love
Reactions: IANZONE and RodPad
Yes, welcome to the forum!
Don't mess with the firmware, the is the LAST thing to try for a problem!!
What do you got going on?
You made 1 post.
It is your turn :) 👌
Rod ..
I have not Used it in couple of years and last time I flew it I had a minor crash and replaced the flex cable. However I can’t get the camera to work properly, it has a mind of its own. Confused!
Reactions: RodPad
Skip the Firmware!!
"flex cable"
Is this the ribbon cable?
@Capt KO
Your there first I found on Ribbon Cables.
Rod ..
Skip the Firmware!!
"flex cable"
@Capt KO
Rod ..
.....and, if the ribbon cable was a knock-off cheap Chinese p.o.s., it probably won't work correctly anyway. Use ONLY OEM DJI parts and components.
And as others have said, do NOT mess with the firmware yet.
@captainmilehigh
There is 2 caps here that go towards the ribbon cable!
For sure seen this many times.
@Premier712
Its you turn!
We don't get paid much. :rolleyes:
Stating what worked.
Is most important!!
Rod ..
You made 1 post.
Rod ..
I had a minor crash and I had to replace the camera cable, the camera is acting weird it moves all around and sometimes an image will show. Other times it’s black screen, also it says umc error. Also, I can’t get to the camera settings on the RC. I don’t have any idea what to do to fix it. Thanks for your response! I am clueless because I have never given it an update since I purchased it in 2018.
Thanks so much,
Terry
Reactions: RodPad
@Premier712 !
You came back!
Keep the thread alive!
So far I only see three posters beside you.
Two of them can help you way better than I. :) 👌
Rod ..
Thank you for your help, and my problem is a after market flex cable.
well friend the problem may not be the flex cable ... if u have a p3p with no camera view u may need to flash the camera live gimbal board .. check this thread Fixing flash in DM365 chip within Ph3 Pro gimbal
do not update the fw
Yes I suspect the problem wouldbe the flash chip, but for me, if it is the case, it is a planned obsolescence case programed by dji. The chip could be destroyed if you dont use the dron, nice. Thanks dji.....
