IMU CALIBRATION
HELLO FELLOW PHANTOM 3 STANDARD OWNERS,I HAVE A NEW DRONE THAT I NEED TO CALIBRATE THE IMU.WHAT CABLE DO I USE?????THERE IS NO USB PORT ON THE CONTROLLER ONLY A MICRO USB??PLEASE HELP!!THANKS!!
You don't need a cable to calibrate the IMU. Follow these instructions:
Reactions: Heep and PKflyer
His Caps Lock key is stuck ;)
Reactions: mdowney58
Just find a cool, level spot to perform the cal. I do mine in my basement. It's cool and stable. I used a carpenter's level to find a level spot on the floor. Let it set for several minuets to temp stabilize.
Something else I discovered that is worth remembering. When You do the IMU Calibration, the ambient temperature is important if done in a Warmish room. When You go to fly, drone seems to want to warm up to that temperature before flight. Do it in a cold room and it will be ready to fly immediately
blomdido, check out the video I posted above. It includes a good explanation of what you're describing.
intertronixlabel
