IMU Calibration. Unknown error at 2%
It probably makes no difference doing IMU as I do ... but as I say - it cannot be bad to take that extra bit of care.
Nigel
Well yes, i have done most of my IMU calibrations indoors but most important is a level surfarce (even pulled out the spirit level) ha..cheers.
I used to do my IMU indoors ... never had any problem, but the line showing Compass always had me thinking ..
Nigel
Often a stuck IMU will be revealed by the sensor screen in the DJI GO app- all values should read zero (or very close) with the obvious exception of the z axis which is constantly acted on by gravity. The IMU values give you a clue as to which way to gently but firmly tap the AC to unstick the IMU.
You guys literally weren’t joking about smacking it on the battery three good times I tried it and now it’s working thank God for you guys
Reactions: Alan Russel
Really, we were just making it up, there is no way that can work... ;)
Glad it did. :D
I have only seen this talked about maybe three times.
Thanks for sharing.
My vote they have to be mechanical, otherwise they wouldn't do what a Gyro does.
Rod
I would think the gyros are solid state. I'm guessing the fan gets stuck. Do you hear a whine when you power up?
