So this is not intended for 90% of people... it is inteded for those of us who SSH into the wifi module and RE and make changes. Alot of changes can be make to improve video quality and range, but that is another thread later
So basically this mod lets you connect to the wifi module via serial. You would do this if you logged into the wifi module and screwed up the config.. if the wifi does not come back up you can not SSH back in to fix it, you would of essentially bricked the wifi unit and had to send it back to DJI or buy a new one, now with the serial connection you can fix it youtself
The only bit of equipment needed is a USB to TTL cable. They usually come with 3v or 5v, that part does not matter as you will not be plugged the 3/5v cable in.
I used this one (as I have a beaglebone anyways) https://www.adafruit.com/product/954
A huge thanks goes out to sea_ow for figuring out the pinouts of all the cables going into the cable/wifi.
I am going to update the thread tomorrow (time for bed) with pictures and exactly how to do it. Its pretty easy but you will need to chop up 3 of the tiny cables that go into the wifi module, if you do it careful you can put it back together easily, if not, but another cable and have the spare.
Will post up the exact cable and pins, where to plug the USB cable connectors in as well.
There is also another trick you need to do before hand, else you will get stuck once the OS loads, the phantom will work but you will have no access to login..the console will essentially but stuck (but everthing is working)
Will post up all the info tomorrow... my eyes getting a bit sore from soldering/looking at tiny wires for last few hours...
I know most people won't care about this but as someone who logs into the wifi module to try get free modifications by changing settiings this is something I have wanted to do for months, and now finally can
