GL300A Remote Controller help
I was able to get to the BOOTME [...]. Did it again where it goes through and stops and says operation completed successfully. That's where I'm stuck. Firmware still will not show in DJIGo app.
You flashed the bootloader, but you did not checked whether the system now boots. Connect your TTL-to-USB again, but instead of opening the port with TI Flash Utility, do it with terminal program like PuTTY.
Also, read this for some details:
Firmware m1300 · mefistotelis/phantom-firmware-tools Wiki · GitHub
This is what I get using Putty.exe and it just keeps going
I changed the speed in Putty to 115200 and now I'm getting the constant BOOTME.
Im getting this gibberish when I connect mine USB board (P00928.03)
It draws 0.7 amp from the 5 V supply which I think is a lot.
I have gnd to gnd, and 5V to 5V
It helped changing speed to 115200. Now I get bootme when btselv and 3.3V conencted. But nothing without the boot wire.
Tried to connect btselv to minus, and got this:
36x initialization passed!
UBL Product Vesion : DJI-GRC-UBL-1.0-rc0(2014-07-31)
Dji UBL Version: 1.51(Jul 31 2014 - 09:23:41)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Valid magicnum, 0xA1ACED66, found in block 0x0000001D.
No valid boot image found!
NAND Boot failed.
Aborting...
For some reason mine gets stuck in bootme, even without connecting the btselv pad, and also after disconnecting the USB and power for 5 minutes.
Anyways, its not a problem, I will just connect btselv to minus when needed..
"No valid boot image found!" <-- Does this mean the kernel is ok, and I need to flash a valid boot image?
Usachman
