Gimbal will not tilt all the way up
This just started happening. My gimbal will tilt only to the level position. Sometimes not even that far. I can't seem to locate the gimbal calibration in the GO App? Where is it located? Any other suggestions would be appreciated.
Try calibrating the remote controller -- like this:
If that does not fix the problem, then check that you have the following setting enabled in DJI GO:
Reactions: Dinerve
Go to your gimbal settings in DJI Go App and select Advanced Settings:
Then select 'Enable Upward Gimbal tilt Limit to 30 Degree'
Honeymoo
