Forward speed slow
Some body please help me.I have a phantom 4 that forward speed is very slow.How ever reverse speed is very fast
How slow and how fast?
What was the prevailing wind when you noticed this?
What mode were you flying in?
AD
AD
Wind was not bad at all. When I fly in reverse speeds are very faster.Forward speed is half of reverse speed
Did anybody find out the answer on this? My P4 just back from repair (a system board they said) and flies only about 5mph forward in P mode but normal speed backward. Thank you!
Hey all, I just got used P4, I had VPS problems, in air, VPS just randomly goes to 0.0-0.1 value and descends slow. I tried to turning it off and desends good. But wanted to try fix it. sensors looks clean, so I tried connect ti dji assistant and perform calibration. I did it with success, but now when I fly my bird, goes slow in forward, like 9-10kph, I think like 6-7mph. In sports/atti mode goes full ~75kph... I did not tried yet to disable obsticle avoidance, but I dont want to disable it. pretty new with big drones, flied a little bit small mini drones. Maybe do factory reset? Or compass calibration? Im using latest firmware.
A little supplied flight data could help figure out the issue. Otherwise you are just guessing. Do not change any firmware or anything else before you see what the real issue may be. If you do, you are adding too many variables to determine what the issue is.
Is there a gimbal guard or something else blocking the downward sensor view?
It's got nothing to do with the compass - leave the compass alone.
Ok, what data do you need? Im little new in DJI ecosystem.
Go to DJI Flight Log Viewer | Phantom Help
That will give you a detailed report of the flight.
so I did flight... DJI Flight Log Viewer - PhantomHelp.com and I can confirm, when I disable obsticle avoidance it goes normal ~50kph speed forward. I also experience problems with RTH... I set my RTH alttitude to 40m but when I press RTH its start facing me and going up... to the limit at 120m and not going back... Maybe factory reset will do the trick with dji assistant? I think this started after I updated drone FW... I ibought it used and it was I think never updated...
Im reviewing my LOG and see that after I pressed RTH it gives: RTH: Backing up to avoid obstacle , looks like front sensors after calibrations are messy... I did calibration on my 15'' laptop, passed...
Did you also disable the downward sensors? According to this data set, you did. That said, with these disabled the aircraft should not climb as it appears to have done. Your RTH was set for 19 meters and you were already above that when you activated RTH. This may indicate an issue with the downward sensors. It is possible that they could be reporting erroneous data, although the data set here does not actually show that since they appear to have been disabled.
yeah, about that vertical sensors... its also little bit messy. Now I ave tem disabled. because when I enable them it shows me 0.0-0.1 values when Im up in the air and descending is very slow then... I did calibration with dji assistant hoping to fix it... But when I turning on P4 and just lifting it from ground, looks like VPS sensors showing good value, but up in te air is something not right... sensors looks clean... and I bought this P4 for 350 euros, it was crashed once, bottom shell cracked near one motor, but flies OK...
I tried record that flight from LOG
@scorpiopaulius I don't recall off the top of my head if the proper data is included, however, you could try retrieving the aircraft .dat file for a more in depth look as to what may be going on with the sensors. If you have never done that, see the link below and follow the instructions. You will need to upload that file to a share site such as dropbox..etc....then share a link back here to the file. The file you should look for is FLY258. Retrieve Aircraft .Dat Log
hcashmore11
