Dji phantom 4 pro gimbal wobbling side to side
Hi everybody! I need help with my phantom 4 pro (v1). When I turn it on it starts wobbling side to side very slow. I have replaced every board on the gimbal and still not working. I dont know what to do next.
Reactions: RodPad
It would help if you could provide some history on the aircraft and the sequence of events that this issue started.
Theres no history of issues it just started randomly. Hoping that somebody with the same issue saws this and knows whats wrong.
Probably damaged yaw motor “Hall Sensors “
A video showing what it does would help us. I am pretty sure it is the yaw motor however
If you replace the yaw motor yourself, be sure to use the original motor casing. I am here to help if you need help
Have changed the whole gimbal. Boards, motors, cables, everything.
It would help us if you put up a video. Without it we are guessing. Also, where did you get the parts you replaced? I have repaired hundreds of P4 gimbals.
Reactions: RodPad
@Jp24
"Theres no history of issues it just started randomly."
History?
How long have you had it, New or Used?
How many flights have you flown on this Phantom before this problem showed up? 10,100,etc.
So far you have 3 members on this thread that know way more than I.
Yes a video seems to be the best at this time. :)
Your Turn.:)👌
Rod ..
