Yup, i use the same amps and antennas for mobile or home.Has anyone mounted antennas on the roof of there house? or is long cable runs a problem..
For long runs high quantity cable is best. LMR-400 works well for over 50'
Why do some people feel the need to tell other people what to do? Or in this case what not to do. JM writes in to talk flying and some wise guy looks at a picture of his remote and begins to preach the FAA guidelines at him. (JM may not be in the US, JMM may have had a variance or permission, or was having a problem with the onboard GPS module-could be any reason) You can't blame JM or anyone for copping an attitude with the hall monitor or bathroom monitor. I would have also copped an attitude. Just saying no one likes to be preached at or told how to fly their drone regardless of the intentions.Still against US guidelines.
Are you in the US?
If so:
Are you registered?
Do you know the FAA guidelines?
Ignorance is one thing disregard is another.
Hi guys, can someone tell me or point to a link that will let me known what the diffence is between RF LINX Bi-Directional Amp MN: 2400SAXU and 2400SAU?
Also, the U stands for ‘user specified parameters’. In the original install the tech could set parameters specific to the site but luckily, the 4 of these amps I’ve bought off eBay, they were all consistent with one another and don’t appear that any of them had to be adjusted.
Thanks, I picked up a couple for a mobile set up. I’m also looking at HyperLink 2.4 GHz 1000 mW (1 Watt) Amplifier for a roof set up. Do you think they’re a good option?
The difference i see in these hyperlink amps you posted vs the rf-linx SAXU amps is the hyperlink only has a 17dB RX gain where as the SAXU has 20dB. 3dB RX difference is pretty significant at the edge of your range. I know which one I would choose......
Yeah notice to 3DB difference but I had to pull the trigger and buy them, because the price was $50 for 6 brand new amps and with power injectors. Which was less than I paid for one of my SAXU and a power injector.
Will do!Good deal! Let us know how they work out!
Will do!
Take advice from all the hours of trial and error that these guys had already accomplished and figure out a way to direct mount your antenna to the amplifier....
I do appreciate you guys doing all the heavy lifting to figure out what works. Right now I have SAXU’s directly mounted to the antennas I have on each side of my shed that sits on a hill above my house.
