First flight :)
Took the P3S for its first flight yeterday. What an awesome bird. So easy to fly it's scary.
After reading up on quite a few fly aways is the general rule to flip it straight into Atti mode? (S1 swtch to middle) Obviously let RTH do it's thing but if that fails?
A fly away is normally a pilot error -- AKA the pilot does not understand why the Phantom is flying away. What you do to recover it really depends on the scenario at hand. For example, if you always just flip it to ATTI when you run into trouble, your Phantom could be carried away in a strong wind (if you don't know it's windy). If you take the time to understand your aircraft, the chance of an unexplainable flyaway will be minuscule.
I would also test all three RTH's under a controlled condition. By the Go app, S2 switch on RC and lastly turning off the power to the RC (fail safe). This way you can see if all is working like it should, and you'll know if all else fails RTH should work.
Reactions: artheserenity
tom sauter
