fc40 camera
It could take up to 4 hours depending on how low the battery charge was when you began to recharge the camera. The camera may feel warm to the touch and a charge indicator light may be on. After the charge, the camera will feel cool and the light should be off. Also, it helps if the charge cable is plugged in a wall outlet instead of the computer as the instructions say.
I've noticed with mine sometimes after powering up it didn't turn on (as if it was dead). I took the micro sd card out and it powered up fine after that. Little tip
