Error when importing .csv file to Litchi App
So I make a set of waypoints using the flylitchi mission hub and exported them as a .csv file. When I import that same file into the litchi app, the coordinates are all over the place and don't line up. How do I fix this?
Why are you manually exporting and importing? Does your flight device not have internet connectivity?
It does, but the goal is to eventually import in a custom set of waypoints without using the Mission Hub at all, so we are trying to figure out the formatting .
Reactions: umanbean
Ah so... sorry can't help you with that, above my paygrade LOL
I have never seen that problem I have flown 60+ missions with Litchi and save .CSVs on each of them. When I reload the CSVs they reproduce the original mission without any problems.
I routinely generate .CSV files in my own app. Written in VBA for MS Access. It may or may not be useful to you as it is designed to fly a rectangular grid of waypoints. You can specify spacing of waypoints (E-W and N-S), orientation of survey, altitude etc and it creates the .CSV. Image of entry screen below
