Does anyone have a copy of firmware V 01.03.0509?
I'm asking my question about the p4p, not the p4+.
I am very interested too as to the answer to this question. I currently run '509' in my AC and 1.1.3.0 in my +RC which is the latest version blessed by DJI for use in a +RC when running '509' in the AC ... so I would also like to know what later +RC version is compatible with '509' as well.
Hi
I'm also interested to know what's the higher RC firmware release that we can load in P4P+ remote control that can pair with AC firmware 0509
I have the same doubt about higher DJI GO 4 version that can works fine with P4P+ AC 0509
Try it out as you don't have much to lose. Just make sure you have a copy of the original FW and a micro SD handy so if you need to reload the controller, you can. It's only controller software, folks!
Index of /DJI-Firmware
use dumldore to get it back to 0509 ( i think 0304 is better). Then download 0300, delete the 306 module from within, flash 0300 (minus the 306 module), over the top of 0509. Now you should be on 0300-, & have all parameter tweaks plus the latest features (pano on p4p+ etc).
I tried that but got "Your flight altitude and distance has been limited" message which I believe is related to a mismatch between the RC and A/C firmware.
My current config.
Phantom 4 Pro
Aircraft Firmware : V 01.03.0509
Remote Controller Firmware : V 1.4.1.0
DJI GO 4 App iOS : V 4.1.12
Apple ipad mini 4 ios 11.2.6
Am I doing something wrong? Any suggestions? Tks. Mark.
i just tried 0509, GO412 and RC 1.4.10. works fine. Could just be a bad flash? I would try again.
good news Mark. Well done mate.
Just as a follow up. I’ve done a bit more experimenting.
Going from go 4.0.8 to go 4.1.12 resulted in the alert msg returning. (Just doesn’t like 4.1.12)
So working config is. Fw 1.03.0509 with go 4.0.8
Also got mixed modules to work with 03.0509 and 04.0602 on top. (Providing parameter adjust and 32 ch)
Mixed 05.300 which also worked but has the inverted image prob.
Can’t find a copy of 05.600 to try. (Yet)
Tks for your help.
Reactions: Firebird
hcashmore11
