DJI Phantom 3 Gimbal Repair Kit
Just published a new video: yaw arm replacement only.
eBay listing for yaw arm only.
Hi tbock. I bought you a couple of days ago the yaw arm on ebay. I followed all your video instructions and everything went fine. Mostly. Now I have these weird effect on the video, and I think I know why. The board that fits in the 3d printed piece, is slightly inclined. I think the 3d piece has this error. Because of this, when I tighten the screws of the back cover (yes, I'm using the ones you supply) the motor doesn't spin free like it used to. But if I loose those screws, everything is good again.
You can see the effect I'm talking with the two upper holes.
Looking to order one of these kits. just curious if there are issues or concerns with using non-oem parts. I already voided my warranty...pilot error crashes
There really isn't an issue with using aftermarket arms, because dji doesn't repair gimbals anyway. Even when you send it in, they just replace the whole gimbal (and usually charge you for it). I think most people don't realize a "pilot error" crash voids your warranty. ;)
Yup, it took me about two weeks to void the warranty on this bird :) I'll be placing my order soon.
I plan to buy your kit , but I need the calbe too, will ti work DJI Phantom 3 Part 42 (instead fo 49)? http://www.amazon.com/gp/product/B0...ue&ref_=ox_sc_act_title_2&smid=A1JL84PCMGC6ZI
Thanks, Rodrigo (from Chile)
Although I'm new to this forum, I've been an active member on RCgroups for a while now. I fell in love with this hobby a couple a years ago and am always looking for ways to support my hobby habit by making products for other hobbyists. The latest project I've been working on should fit in great with this group!
If you're like me, you've just realized that your shiny new DJI Phantom 3 is far from indestructible. Even a "rough landing" can cause enough damage to your camera gimbal that your only option may be to completely replace the whole camera/gimbal assembly!
Every once in a while, there's an "Option B": Buy someone else's broken gimbal and hope that you can piece together one working gimbal out of the two. You might be upset with DJI for making such a fragile gimbal, but that's the price you pay for the great flight time.
I'm here to offer a third option, and I truly believe that it should be considered "Option A". I've spent weeks testing and refining a 3D printed alternative for DJIs aluminum Phantom 3 gimbal arms. I've assembled a gimbal repair kit that includes the yaw arm, roll arm, specialized tools, and video instruction on how to perform the repair. I also offer email and phone support to anyone who buys my kit.
I know many of you are skeptical about a 3D printed part being strong enough to replace the stock aluminum arms. It's a justified concern, but not all 3D printed parts are created equal. There are many people out there selling parts who don't have the necessary skills or experience to print quality parts. About 80% of parts being sold aren't even designed by the people who print them. I'd like the chance to prove to you that the "average" 3D printed part doesn't even come close to showing the full potential of what is possible with 3D printing technology. 3D printing is as much an art as it is a skill. The best comparison to working with a 3D printer is woodworking. When you print with plastic, you need to consider the "grain" of your part the same as if it were made of wood. Your print is going to be stronger in one direction than another, this needs to be considered in the design phase. A good designer can use these characteristics to their advantage to turn weakness into strength and impossible into incredible.
I'm not going to try to convince you that these parts will hold up better than the stock DJI parts because that might not be true. These parts will likely break in the same conditions that break the DJI parts. I could make them stronger than DJIs parts, but that would do more harm than good in a crash. If the arms don't break in a crash, the motor shafts will. If the arms are the weak spot, good! That is the cheapest repair. I can say with confidence that the parts I'm selling are strong enough to be a solid and reliable replacement for the stock DJI parts. Some extra care is needed during assembly because of the small screws, but that's common sense stuff and is covered in the instruction video. Once your gimbal is assembled, the replacement parts are very sturdy and don't require any special treatment. This kit is designed to use all original screws. If your yaw arm broke at the motor shaft, you may need to buy a new M3x4 set screw to use with the new yaw arm.
This kit includes:
•Yaw Arm
•Roll Arm
•Roll motor alignment tool
•Hardware layout sheet
•Video instruction guide (link to my YouTube videos)
•Email and phone support
Things you will need:
•Philips screwdriver #PH0
•Allen driver 1.5mm
•Torks driver #T6
•Hobby knife or small pick
•All original screws
I chose not to include a new ribbon cable (DJI Phantom 3 Part 49) in this kit because not everyone will need one. You can salvage the original if it's not damaged. Just be careful, a replacement will cost you about $50.
Here's the videos I've made to help with the repair.
Video #1 shows disassembly:
Video #2 shows assembly:
Video #3 shows yaw arm replacement only:
Video #4 shows a powered test of gimbal movement.
Video #5 shows test flight footage.
I made a few small changes to the design of the roll arm since the assembly video. The parts in the photos and powered tests are the final version.
*There is no guarantee that this kit will fix everything that's wrong with your gimbal. This will only replace the bent or broken arms.
I'm selling these kits on eBay for $75 + shipping.
You can buy the yaw arm only for $40 + shipping.
DJI Phantom 3 Gimbal Yaw Arm
Hi,
I am trying to fix my Phantom 3 Advanced Gimbal.
It requires a new yaw & roll arm plus flat cable. I only discovered the roll arm was not at 90 degrees after i started to re-build the gimbal.
However, i am unsure how to detach the roll motor from the roll arm. I cannot find information on how to do this on the internet, and am worried that forcing it will cause further damage.
View attachment 36921 Hi,
So nobody knows how to remove and or replace?
This kit includes:
•Yaw Arm
•Roll Arm
•Allen driver 1.5mm
•Torks driver #T6
Hello friend I have crashed mine lately could I have the gimbal only
dude! your amazing, I was wondering when some one was going make these parts. I hope you got a patent on your work. its people like you who keep the big boys in line. I crash about every time I fly the last time was a bird. (they don't like drones). my middle name should be crash. im about to order 2 kits. ill try and fix some of the camras I have been saving for a time like this. ill be a reg,cust. my phantom 3 pro has all new parts now (more on the way) I was thinking of starting a drone salvage shop. lol thanks again bro. ps your vids are the only ones I like your cool, collective no, b.s. cutoos keep up the great job.
Hey Tbock I just sent you a PM. My mishap was not too bad and it should be an easy fix for you. I'm excited to see how it goes and I'd be pleased as punch to save $500 bucks by going the OEM route. Let me know how to get it to you and I'll send it right off.
Outstanding thing you have going, congrats.
Pic of damage
Hey Tony, I have been trying to contact you but I'm not getting a reply. The last I heard from you was that it should be ready Monday, last Monday the 21st.
I am interested in paying you and getting my gimbal back. What do I need to do to get this moving along?
I've made a re-shelling to my Phantom3 Professional and all is gone right except for the gimbal: is there anyone who knows how to control the gimbal and understand from which the problem depends (the flat cable to yaw motor or other)?
I did it once. I used a pair of pliers and just kept working my way around the outside. It slowly came out. Hard to describe what i did ...sorry. It appears to be just a tight fit. Be careful and go slow.
Hello Tbock,
I am about to order the repair kit, with paypal, but is it possible to add the flat cable ?
I am from Bulgaria and here it is very dificult to find one.
Thank you
Stefan
Good to know. The good thing about capitalism is we can choose who we buy from. I choose many different companies. Fstop labs is just one of them. I also choose not to use ABS. And only use aluminum. I have a whole pile of ABS with stripped screw holes. About $200 worth. Must be me
