Disable return to home
Is there a way to disable return to home? I am going to be flying around some trees, and if I loose signal I'd rather have it land where it is versus shooting up 20 meters straight into the tree tops.
Thanks
I wasn't able to locate it in the PHANTOM 2 VISION+ USER MANUAL (EN) V1.1.5. I'm assuming it would be listed in Section 4: Failsafe Function, but all that describes is what the failsafe is and how to regain control.
Are you referring to documentation on the software itself? If so, I wasn't able to locate this documentation, other than the online link provided, http://wiki.dji.com/en/index.php/Main_Page, which seems to not be what I need. I'll poke around the software later to see if I can locate the settings.
It's right in your assistant. Just click on the tab and you check what you want either go home and land or land.
Supercell
