Descending on hover.
Malvern, Worcestershire, England
I find that whilst my drone is hovering it tends to descend slowly. Never left it high and see how it drops but I do notice when I am bringing it into land I leave it around 10 feet in the air and it slowly descends.
I also notice that as I land it often 'bounces' comes down and as I get close to touch down it always gives a bounce up again. Is this just prop downdraft hitting the ground or the sensors underneath? Both?
Just curious.
Compass. IMU both recently calibrated.
There is an air cushion from the down draft as you descend, you get used to it.
Just take it easy and it will kiss the ground like a feather.
If you hand catch with the camera at eye level so you have reach up slightly you should be fine.
I shut off VPS never done hand catching probably never will. There is sometimes that updraft of air when landing but with VPS on it tends to go up more and higher.
if it does decend on it's own from that height, you can bet that the barometer is not working right.
Reactions: Frankc
intertronixlabel
