Couple issues - distance limitation and weak image transmission...
Thought the distance limitation (vertical and horizontal) was fixed in GO App v 3.1.15 for IOS. It's not - only way I found around it is to logout of the App and cycle the RC and AC - I also cycle the iPhone this works every time. Definitely a GO App bug.
Also the Weak Image transmission issue - read somewhere pairing the AC and RC units helps - did that. Also shut off all WiFi sources at my farm and thought it might be good to shut off the WiFi on my iPhone running the Go App. Vast improvement - flew CrashCraft a mile out at 250' and had one minor blip - normally would have had 10-20 major gaps in video weak trans..blah blah on the same flight path.
More tests to go but encouraging progress today.
Did you try just restarting DJI GO?
