I have a solar panel to keep the car battery and charge the LiPos went im in the field.
I would like to see that panel's specs. Typically, solar is good for an anemic trickle charge at best.
...A 5400MAH 3S pack can draw 5.4+ amps while charging. 3 could draw 16.2+ amps.
How long have you been doing this? Noticed any issues with heat or signs of current overload when the engine is running (the voltage would be higher with alternator turning)? One last question as this seems too good to be true to me being as I currently use the invertor to run two chargers while engine is on. How long does it take you to charge the batteries?
What size and brand of solar panel works best?I have a solar panel to keep the car battery and charge the LiPos went im in the field.
The battery for P2 is 11.1 Volts 5.2 Amps so any voltage above that will charge it.Why not use a solar charger rather than an automotive plugin? What level of voltage is best for charging the DJI 2+ batteries? There should be solar panels just right for charging.
It seem to work through the 12 volt on the car with this item.
Battery Parallel Charger Charging Board Plate for DJI PHANTOM2 Vision Quadcopter | eBay
But I didn't get really get test it. Time voltages and amps.
