New P3P. Camera on replay is very jerky. Have vision 2 and2plus no probs with them. Any advice?? Thanks. Jerry
What do you mean by "replay"New P3P. Camera on replay is very jerky. Have vision 2 and2plus no probs with them. Any advice?? Thanks. Jerry
I should have said when I play what I recorded. SorryWhat do you mean by "replay"
What are you playing it back on? What resolution are you recording in?I should have said when I play what I recorded. Sorry
OK, you must be hitting the 'Play' button on the app while connected, this streams the recorded video from the camera sd card via light bridge and is S-L-O-W, as that is the only way you can play it back on the iPhone other than youtube. Remove the sd card and using a reader insert it in your computer, it may still be choppy as the mackbook air isn't that powerful.Should it be smooth playing on iPhone 6. Also thanks for quick responses.
just put it in daughters PC and it worked. Time for a new computer. 3 different Macs wouldn't play it and I'm a Mac guy. Thanks again for the advise. JerryOK, you must be hitting the 'Play' button on the app while connected, this streams the recorded video from the camera sd card via light bridge and is S-L-O-W, as that is the only way you can play it back on the iPhone other than youtube. Remove the sd card and using a reader insert it in your computer, it may still be choppy as the mackbook air isn't that powerful.
Jerry, my iMAC 27" i7 3.4GHz plays it just fine, the laptops and tablets have low power processors not built for power but for power saving. Most desktops will play 4K.OK, you must be hitting the 'Play' button on the app while connected, this streams the recorded video from the camera sd card via light bridge and is S-L-O-W, as that is the only way you can play it back on the iPhone other than youtube. Remove the sd card and using a reader insert it in your computer, it may still be choppy as the mackbook air isn't that powerful.
My 4 year old MacBook Pro 2.2 GHz i7 plays raw 4k video, even with the graphics card disabled. If you have a Mac that's newer than that, you may just need to upgrade to a solid state drive and upgrade the amount of RAM. When I upgraded my hard drive to an SSD, I went from 50 MB/sec up to 500 MB/sec. Mine still stutters every now and then, but I'm assuming that's probably due to running on 4 GB of RAM. I plan to upgrade to 16 GB one day...just put it in daughters PC and it worked. Time for a new computer. 3 different Macs wouldn't play it and I'm a Mac guy. Thanks again for the advise. Jerry
Yep, a SSD makes a lot of difference for sure, gave new life to my wife's 6 year old iMac, OWC has some great stuff for MAC's to speed them up.My 4 year old MacBook Pro plays raw 4k video, even with the graphics card disabled. If you have a Mac that's newer than that, you may just need to upgrade to a solid state hard drive and upgrade the amount of RAM. When I upgraded my hard drive to an SSD, I went from 50 MB/sec up to 500 MB/sec.
That should play 4k without flinching... Did you move the files onto the SSD prior to viewing?hi
i have the same issue, on i7 5930K 4.3ghz, 32gb, M2 256gb......! no mater full HD or 4K same
thx
What is your video card? Even the onboard GPU built into the i7 should play 4K just fine unless you have a tons of other applications up and running.hi
thx
Thread starter | Similar threads | Forum | Replies | Date |
A | Flashing red light next to micro SD port, and camera issues - help! | Phantom 4 Pro Discussion | 4 | |
G | DJI Phantom 3 Pro - Camera crash Issue | Pro/Adv Discussion | 3 | |
D | Camera issues p3a | Pro/Adv Discussion | 9 | |
C | Phantom 3 Pro Camera Issue | Pro/Adv Discussion | 2 | |
M | Camera issue, frame skipping black bar | Phantom 4 Pro Help | 0 |
