Cables
Well if they did I would be out of luck View attachment 62102 The others are better as Pro said these I just found these when I did my first one .
Also I never remove my panels . The cable's he mentions went in the trash . Don't know why they send such thin ones for inside the TX .
For what is the third switch on ur rc?
That is a slow-mod switch that J Dot makes that when on slows the yaw way down . Not sure what percentage and have it on my P2V
then tried it on my Standard and worked just as good . This was taken from the P2V but shows you how much it does slow it down .
First spin is with it off with the yaw stick push as far as it can go them with it on the same way .
This looks sloppy but isn't really .
Lots got them and he makes them where they are plug and play so real easy to install .
Reactions: Mark The Droner
wkflysaphan4
