- Joined
- Nov 12, 2015
- Messages
- 480
- Reaction score
- 109
- Age
- 46
McVentures,
I really do not this was your fault. I have been lurking for awhile as I consider a Phantom purchase and this story lead me to sign up. Below are the reasons why I believe it was not your fault, assuming the crash was related to a prop coming off.
1. I have watched almost every video and review of setup and first flight and it doesn't look like any of them do much as far as prop tightening goes. And they seem to have no issue...
2. Having the motor spin in a way that tightens the props is by design. I have big doubts that there is any active braking, if so and if it was severe the prop attachment method seems like a defective design. Furthermore if it was present it seems like DJI would put a lot of emphasis on tightening the props. I also think the air resistance probably is enough to slow the props down that active braking is not needed. All that being said, I am not a complete expert and maybe it does have active braking.
3. Even if it did have active braking, you were not flying aggressive, sounds like barely hovering, seems like there would not have been active braking just before your fall.
4. If it had active braking you would see it in the log file of the motor that lost the prop. You would see a very rapid drop in RPM caused by active braking followed by a rapid increase in RPM after the prop came off. If someone can post each motors speed over the flight I would love to see it.
5. Are we sure the RPM is actual and not target or calculated? Do the motors have at least 3 wires?
6. If would be cool if Steve posts which prop he believes came off from the log files to confirm it is the same one that actually did.
7. If the prop hit something I believe it would only have tightened it.
Don't give up and follow DJI support. I have not purchase yet as I have fear of technical issue and want to see how DJI handles it...
