Is anyone else getting stress cracks on the P4 batteries? I'm getting them specifically on the front near the LEDs... No cracks in the drone though.
That's a common place for stress cracks on the P4 batteries. If you contact DJI support, they will likely replace them for free.
Yes, the click you hear when you push the battery into the craft is a spring snapping against the inside of the battery just under the battery level LED. Some early batteries are prone to cracking.
I have three batteries and one of them is cracked. I never bothered getting a replacement. It seems to be cosmetic only. It happened last fall and hasn't grown larger since....
That doesn't help, I've always held the buttons down when inserting battery and mine has cracked.I dont click the batteries in anymore, i hold the battery release tabs down while sliding it in, then when in give it a nice firm push followed by a slight pull to check its locked in
If it's less than 5mos old, fly it as long and often as possible, saving your other batteries. I suggest you call them at 5mos old and get it replaced.Thanks everyone! Very informative. If it's only cosmetic, I'm going to keep them. Thanks for the advice!
Just to let you know... I had very simular stress cracks on two of my batteries for my P4 and just flew with um thinking it wasn't harmful to the battery. Well after reading this thread I contacted DJI... sent them in.. and I'm getting two new ones! Not bad... thanks MSINGER...
Thanks for responding! I'll try to contact them today.I've had them since the P4 came out... long time.. I really don't remember how old.. but if you chat with them online... send them a pic... they will have you send them in... I doubt they would send back batteries for you to use with cracks... give it a shot!
