- Joined
- Jul 9, 2014
- Messages
- 242
- Reaction score
- 48
itchybeard said:Hi, Saao
I have started using "Vision+ Utility Pro" by Taco RC, because it allows you to boost the Range Extender as well as the Wi-Fi module in the bird. It also has a handy flight logging feature.
Now then, I have been looking at the spec of your RF amp on the Horizon webpage ....
http://horizonfpvantennas.mybigcommerce ... mp-1-watt/
Note: The input power is from 1mw up to a maximum of 100mw.
TX Input Power: 1 mW (0dBm) min up to 100mW (20dBm) max
If you use this amp with your transitter in FCC mode (100mw) then you are right on the maximum limit, and if your transmitter peaks at above 100mw you are likely to flood the amp causing dropouts in the link. You may even end up burning out the amp.
If you use the amp with your transmitter in CE mode (25mw) you are still well above the minimum input (1mw), so you will still get your 1000mw output and even if your transmitter peaks at 30mw then it would be well within the limits of the amp, geddit?
All the best
Itchy
Hey Itchy,
I've been a long time lurker on these forums having bought my P2V+ back in July. I've recently been dabbling with antenna mods and have installed my transmitter antennas with great success (I also removed the glue for a better connection). Anyway, just want to say that this particular post was very useful indeed. I've been thinking about getting powered boosters but had been put off by other posts saying an attenuator was needed for the 2.4Ghz to reduce the input signal, but your utterly common sense post made me realise that all we need to do is use blummin CE mode! Like you say, it doesn't matter if the input is 10mw or 95mw, the output will still be 1000mw. Better to have a lower input and prolong the life of the booster!
Cheers mate!
