2 Drones and 1 Advanced Radio Transmitter?
Can you use 2 Drones on 1 Radio I.E. Will the new transmitter store 2 bindings to 2 different Drones?
Trying not to buy another Advanced Transmitter & ITElite external antenna system.
I realize I can transfer the antenna but can I just use 1 Radio?
Denny
You can but you have to link the RC to the unit you want to fly. Easy to do but not to both at same time. All that is required is to turn the RC off. On the bottom of the quad push the link/link indicator button in, turn on the RC and it will beep when it's linked. Takes just a few seconds to do.
Thanks I wasn't sure if it needed to "Bind" to both drones for the MAC address before both cameras would work or if I needed to Bind and Link when ready fly #1 or #2.
Obviously I'm not trying to fly both at the same time.
But I'm sure someone has attempted it.
Denny
I thought this was a drone scat parody, 2G&1Cup.
The answer is yes but you need to do both controller and FPV.
You will need to bind the 5.8ghz controller (button on the belly of phantom).
You will then need to bind the 2.4Ghz RE700 (white range extender) done via the DJI Vision App, either by manually entering the mac or by QR.
I went thru this twice today and have just decided to purchase another Itelite antenna for the second radio.
Thanks for all the help.
d
