flying for distance battery turns red at 62 percent then back to green at 58 percent in video why
that's what I was thinking alsoThat is weird. I noticed when it did it you had just turned back. I think it is the algorithm it is running to figured out if you will make it back.
Well maybe it was trying to get it home in time. Hopefully somebody will verify.no looked at all battery's show all normal cells
next just have to turn that off always a field to land inNote the prior on screen message "Lower charge limit reached". Based on smart return to home calcs, the Phantom is indicating you will be in the red zone by the time you get home, even though the battery still is over 60%. If I remember, you made it home with under 30% battery. As we talked about, turning off smart return to home, you would not get these indicators, but you better know how much juice you need to get home.
