OK. Thanks for your reply Fly Dawg.There are really too many variables to consider to answer that question in direct terms. When flying you have to consider, wind, temperature, and other factors as far as "efficiency" goes. It does not matter what aircraft you are flying.
The most effiicient speed is zero, however this negates most desired actions.
Good points.
But as suggested flights are dynamic and worrying about one or a few more minutes of flight time seems to be opposed to the idea of gathering the intended data or images or just enjoying an ‘adventure‘.
Thank you very much. I understand there are a lot of variables out there as to how much actual distance you can get out of a battery, but it seemed reasonable that there might be a sweet spot in there somewhere.Your question is a reasonable one and it has an answer- 14ms will give you best distance on a given charge for a P3 and it’s simillar for the 4 variants. Wind and other conditions may see the actual distance travelled as less or more over the ground however 14ms airspeed will give you greatest distance always. And yes, Transitional lift applies.
Check out these search results for additional interesting reading.Thank you very much. I understand there are a lot of variables out there as to how much actual distance you can get out of a battery, but it seemed reasonable that there might be a sweet spot in there somewhere.
Yes- I posted this link long range drone DJI Phantom 3 professional in that thread.Check out these search results for additional interesting reading.
This particular thread has good data I think.
Cheers!
No- simply because maximum distance is attained at a specific power consumption is somewhat higher than the minimum that provides for level flight. We are looking for greatest possible distance flown as opposed to longest airtime (which could be determined by your method easily).Pretty cool stuff, thanks for finding that thread! I wonder if one could come to the same conclusion by looking at the power consumption at different speeds, as I suggested. In theory, yes.
How? Specifically how will knowing the instantaneous power consumption help?You are right that airtime doesn't equal distance, but airtime x speed does, so my method can still be used to determine what speed gives you more miles per battery.
Flying at a constant speed the steady state power consumption will give you time to empty. Factor in speed and you will have total range at that speed. You will still need to do a couple of runs and some trial and error to get to the magic speed for max distance.Give me one sec... want to make sure I have a good example...
