msinger
Approved Vendor
- Joined
- Oct 30, 2014
- Messages
- 31,963
- Reaction score
- 10,787
- Location
- Harrisburg, PA (US)
- Website
- phantomhelp.com
I really feel a lot of the above is not correct.
I have never read in any documentation that the Phantom will RTH by retracing it's recent course under any circumstances. After reading the manual, this is what I understand.
“Smart Return Home” denotes that the remaining battery capacity can only support the aircraft from return to the home point from the current position hence the app will prompt a message to notify that RTH is being invoked to bring the aircraft back to the home point at that moment. Object avoidance is active. You can cancel if you don’t want this to activate.
"Failsafe Return Home" will do the same as above, except it is invoked upon signal loss of 3 seconds or more duration.
From 27 seconds to about 50 seconds I had no TX connection and the bird backtracks instead of beeline straight home. Please note the video was to demonstrate an RTH ascent bug for DJI but you can see the backtrack work.Got a link?
Can you show us the recorded log so we can see what it was actually doing? You don't really know from this what was happening.Please note the video was to demonstrate an RTH ascent bug for DJI but you can see the backtrack work.
Since there was no TX signal there is nothing during this timeframe in the log from the TX for me to share. Also did you miss the part in the manual under failsafe where it talks about retracing? I'm not sure why you are refusing to acknowledge this feature exists.Can you show us the recorded log so we can see what it was actually doing? You don't really know from this what was happening.
Please explain then, happy to be corrected.I know it's confusing, but "Smart RTH" is not the same thing as "Smart Return-to-Home" (which is not covered in the Phantom manual).
I don't think I said that, but I am keen to see what happened. I haven't heard this mentioned before and it would be good to understand what happens. It would be interesting to just have a drone flying past not too far away and then just turn the controller off to see what happens.I'm not sure why you are refusing to acknowledge this feature exists.
On the rc groups thread there are DJI staff who post. They are the ones who verified the 60 seconds. I've explained exactly how the retracing works so you know what happens. Test it yourself if you like. It's easy to test.I don't think I said that, but I am keen to see what happened. I haven't heard this mentioned before and it would be good to understand what happens.
This seems pretty clear on Page 15 of the manual saying the craft will "...retrace it's original flight route home".Wow, so DJI might have been lying about RTH backtracking?
My apologies, no I hadn't noticed that this was P4P.GeoffJ, you do realize you're posting in the P4P forum, right? The manual and video you linked above are for the P4.
The backtrack is only available on the p4p. The p4 does not have this feature. The p4p is a very different craft. I have owned both. My video clearly shows my aircraft backtracking a good 30 seconds.My apologies, no I hadn't noticed that this was P4P.
Irrespective however, it's difficult to believe they would change the strategy of this basic function, and it will be interesting to see the results of a simple test.
If someone could just fly off for 150 metres or so, go a similar distance at right angles, and then turn off the controller, we should have a clear result.
