video signal interference on FPV
Running the P2 with a H33D (with Hero4). TX/RX is a R5800X. I am getting what appears to be a rolling bar or signal from top to bottom when the P2 is sitting still and motors not running. I occasionally get some signal break up. I haven't run the motors indoors as yet to see if the issue is present then too. Any thoughts on this before I replace the TX/RX system? Can there be a bad connection for example? If there is any info someone needs to help decipher the problem, let me know.
thanks in advance,
Eric
I had the same problem. For me it was the ribbon cable connection from the gimbal to the usb plug for the gopro. It was broke at the usb plug inside the sheathing. I replaced and it went away. connection.jpg
